1 members (JW51), 137 guests, and 2 robots.
Topics128,049
Posts1,055,741
#169990 03/19/2005 12:06 AM
Junior Member
Junior Member
I would like to upgrade to disc brake front.What years are a direct swap in for my 63 GM 1/2 ton smile ?
#169991 03/19/2005 3:14 AM
Z
Z Offline
63-87 c10s will MOSTLY bolt in.
#169992 03/21/2005 2:32 PM
Junior Member
Junior Member
Like Zenish said, mostly.
The crossmember is held to the frame with 14 bolts. 12 of them line up directly. The other two are real close, and will line up if you egg the holes slightly with a drill bit or grinder. The first twelve will get it in and aligned and secured though. I've left those other two bolts out a lot of times and never had any problems.
Tender caretaker of antique tractors and old trucks.
#169993 03/21/2005 2:47 PM
You can use 71-72 spindles w/matching ball joints, either the swap steering linkage or use adaptors from CPP, easier than doing the whole crossmember. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
