BigMac-
Our warm weather has you working on the truck! Gotta love spring.
Using the
Chevy Trucks page I have noted before, it looks like 47-54 chevy trucks should run 60-62 inches in width. The 3/4 ton has a heavy duty, floating rear axle, but I believe the plate-to-plate width is the same. Check the Explorer width.
As far as the U joints with the current shaft put in with the 350 auto transmission combo, also examine these on your truck and compare to the Explorer. What type of tranny did the PO drop in? Should be compatible, but you should check it out first.
Finally, you'll probably have to consider suspension when you swap. Where are the perches on the '93 Explorer? Did you want to upgrade rear suspension too?
Hope we get to see some pics of the beast soon-
