0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
I don't doubt this question hasn't come up about a half dozen times, BUT my wife don't let me come in here very often and I missed any previous discussion. SO -
My 1.5 ton does NOT have a Polarity Reverse Switch (PRS)on the starter. It is a 6 volt. But when I turn it over, it grinds VERY slowly, even with a new battery on full charge. I have 3 ground straps, 1- Cab to frame, 2- Starter to frame, and 3- Neg battery to frame.
MY QUESTION IS: Will adding the PRS make it turn over faster??
Timmer
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
I don't think so.I think it will cook your starter.check the starter brushes,see how many amps the starter is pulling,may have a bad spot in the field.you can try a 8volt battery
dan-pa
Timmer!
If you are not using good heavy duty 6 volt cables, and those on there are 12 volts---change them all.
If the starter is in good shape it'll turn like a turbine with the right size cable on there.
George
Sounds good, BUT I had the starter rebuilt, but have not checked the field,
AND
I purchased the cables NEW from Jim Carters for the 6 volt.
I just thought I was missing something with the PRS since it was not on the starter, (never was).
The PRS was used to switch the polarity going through the points and coil. It did not affect the starter current.
1951 1 Ton Completed
