2 members (Peggy M, crenwelge), 173 guests, and 3 robots.
Topics128,077
Posts1,056,015
Members48,433
#169491 09/16/2004 7:05 PM
Ok i am almost done with the bottom of cab, I keep looking at the gas tink inside the cab. Dang gone it Ben get it out of there. Great tank been pressure tested by me no leaks. Anyway I do not like the prices (under the bed) the magazines say they are worth.
What are my options, I have an extra racing fuel cell, my speed shop guru says he'll build one around $210.00 if I remember right. Buy a used mustang tank or what have you guys done??
popcorn The Truth is Out There (See I do ask truck questions is this the right forum?)
Your right not wanting to be the first one to the fire
I took out the spare and put a NASCAR style 22gal there
Now I carry a AAA card instead of a spare
Put a 'lectric pump near to the tank and and a filter in the line....
I found a nice one with a water stripper and it fit nice in the frame
3/8 ID fuel line........
I scrapped a 1978 1-ton chevy van based motorhome and took the 35 gallon (or so) tank out of it. I fabbed a few brackets and fitted/hung the tank under the bed, just behind the rear axle. The filler spout is run out the back on the left side, just under the rear bed support. My original tank was trash when I bought my truck and I had the other tank so I made it work. I never liked the idea of a gas tank in the cab.
Anonymous
Unregistered
Anonymous
Unregistered
Popkorn - I used an 18 gal tank from an first gen camaro behind the rear axle of my 54. The same would work for your 59. Another option if you want longer legs (more gallons) is to use a 69-70 Mustang tank (20 gal) which can be had off ebay for less than $150 complete with sending unit. You might have to ohm down the sending unit so your guage reads correctly but that is easy to do.
Other options depend on how you have routed your exhaust but the side tank from a 73-up half ton Chevy can be made to work also.
Go Astros! Hope you get another chance to wear the "SHIRT".
I have 20 one gal. milk jugs in mine grin
Redryder pix
My Hotrod
Thanks Guys: I'll print this off after a few more ideas. darn't I aint tight ok yes I am but I know there is things out there that "I" can make work just needed a little direction.
I do like the idea what ever I get, to run the filler neck up to the floor and then use the billet plate and gas cap. Simple and easy to fill.
popcorn The Truth is Out There (Thanks guys, Fred I'm sending you some pills, gas in milk jugs is not good. Gives ya hic ups) Before I forget GO CUBS!! Hehee Mr. Houston)
#169498 09/16/2004 11:12 PM
The fuel vapors from my behind the seat gastank are usually quickly dispersed by the exhaust fumes that come through my firewall...
54 3100 with 235
62 flatbed dump C60 with 261
The under bed gas tank in my '48 is coming out to fix a leak on its top. I hope it's the sender gasket. If not, I might have to get another one since this one has already been sealed with Bill Hirsch's stuff. I'll keep driving it using 6-gallon boat gas can in the bed.
see, that's what ya get for buying one of them little trucks. in cabover land ya can bend the hose from the bottom of the carb that runs to the firewall mounted air cleaner and just pour in the gas from a fruitjar. speaking of fruitjars, anybody seen richard simmons lately? i have a 50 gallon between the rails tank that i rescued from an ambulance. interested? of couse ya gotta do a 2nd mortgage on the house to fill it.
Hey Mighty Warrior: Good to see you, been watching getting few bolters from our area bouncing in here. Fruit jars are only good for one thing and it aint fruit. Makes Giant Head frisky and Maws mad.
popcorn The Truth is Out There (Someday stovebolter party at Planet Wabash)
Ok guys I just took ownership of a gas tank from a fellow stovebolter name will be withheld but something about wearing a dang blasted Astro's Shirt again.
Also just called CCP Classic and ordered all my disc brake hardware, remote filler, stockpedal brake booster kit.
popcorn The Truth is Out There (HAPPY< HAPPY< HAPPY< grin smile grin I love this place)
#169503 09/17/2004 10:16 PM
Riiiight-onn!
Hey, did you go with the six or five lug kit?
Any ideas on where you'll mount the tank and what differential you will use?
(BTW -- did you mean CPP or CCCP ?)
#169504 09/18/2004 12:21 AM
Norse My man: 5 lug, the tank will fasten to the back rail after a little mod, already got a 1969 Grand prix axle rear end bolted up perfect.
Classic Performance out of Calif. they had a sale on everything I needed. Nice guy I talked to didn't try to sell me anything I didn't need.
popcorn The Truth is Out There (I am soooo excited)
My brother-in-law just located a 71 Blazer tank for me but my wif's cancer has put the brakes on EVERYTHING! Gotta earn the money to pay the bills, be a full time nurse and a full time secretary now. No time or money to put into the old 'bolt' now. Probably won't be for quite some time to come. frown
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless!
My 1962 Chevy C-30
My truck is a one ton with a home made flat bed so I bolted a twenty gallon water tank under the side of the bed on the left side in front of the back wheels. A stick will work for a gas gauge.
I like old trucks
