7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
92
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2002 Posts: 4 Junior Member | | Junior Member Joined: May 2002 Posts: 4 | I have towed a 3000 lb trailer for many years with a carbureted 350 sb/350 th setup in a '52 panel with an aftermarket radiator (US Radiator) a trans cooler, and a large electric fan, but I always run on the hot side (not overheating) at 65 mph on the level or when going up grades in the mouintains. Now I am building a '56 3/4 ton for the same application, with a fuel-injected '94 350 sb and a NV 4500 5 speed. It has a belt-driven fan but, as of yet, no shroud. (The engine I am using ran with an oil cooler in the original '94 one ton donor, and I assume I will do the same, which will help cool it.)
The cross-sectional area of the '56 3/4 ton radiator is more than the '52 1/2 ton had, and it is in good condition, 2" thick.
I would like to know the experience others have had running small blocks in 55-57 trucks with stock radiators vs. aftermarket radiators, esp. in trucks often used to tow. I don't mind spending 4-500 bucks for a custom radiator, but I don't want to do it unecessarily.
Also-- how important is a shroud for this application (mechanical fan) and what brand/supplier would you recommend if I need to get one.
Vttinkerer | | | | | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | let me know how you like your NV4500. I'm using the same transmission on my '53 3/4 ton but with a 292 6 cylinder. I'm using a new stock 4pass radiator and an electric fan. Unfortunately I can't tell you how well it cools as my project is unfinished. good luck
'53 chevy 3/4 ton
| | | | | Joined: May 2002 Posts: 4 Junior Member | | Junior Member Joined: May 2002 Posts: 4 | Well Johnny, you obviously knoow why I went out of my way to use a NV4500-- the low,low 1st, the high, high 5th. I wish I had gotten a later one (the shift effort in 3rd gear is said to be less, and there is a synchro on reverse) but beggars can't be choosers. I have driven a NV4500 quite a bit, though, in a Dodge 3/4 ton truck, and I liked it in that application.
What do you mean by a "4 pass" stock radiator?
vttinkerer | | |
