| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16908 04/25/2002 6:05 PM | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | I'm having a little problem with my '49 1/2 ton. Stock drive line. I can't shift out of 2nd while driving. Sitting still I can run through the shift pattern just fine but, moving it won't shift to third. Clutch, pressure plate, throw out are all new and adjusted per fact. manual specs. also, have checked shifter alignment per manual specs. Is the syncro going bad? Is this something I can check by pulling the side inspection cover? Or am I gonna have to pull the whole #@** thing back out? | | |
#16909 04/25/2002 7:37 PM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | Sounds like there's some kind of interference in the shifter linkage that only shows up when the tranny is under load. I'm not sure what you mean by "shifter alignment", but I would check the entire linkage system to make sure that it's tight, no slop, and that it works well in all gears. If you put it in third sitting still, and then try to take off, does it act like it's in third gear? Can you double clutch and get it into gear? Does it grind the gears when you try to shift? | | |
#16910 04/26/2002 12:51 AM | Joined: Oct 2000 Posts: 108 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 108 | Baldeagle,
The alignment I'm refering to is in the factory assembly manual under the heading trans. It tells the proper adjustment of the shift rods, etc. I can take off from a dead stop in 1,2, or 3 rd gear. I just can't shift from 2 to 3. I can shift from 1 to 3, then down shift to 2. But, then I have to come to almost a complete stop to shift back out of 2 (either to 3 or just to neutral). Double clutching doesn't work. It does not jump out of 3rd or anything like that. Like I said I can shift it smoothly through the gears sitting still. The linkage has a little play in it but, I've driven trucks with much worse. When driving in 2nd it grinds if you try to shift, kinda like if you weren't using the clutch at all. But, it will not come out of 2nd unless you are almost completely at a stop. | | |
#16911 04/26/2002 4:40 AM | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | From your description, it sounds like there's something wrong with second gear. I believe I'd yank the tranny and pull the cover off and inspect the gears real closely. It may be that the synchro for second has a burr on it which keeps it from releasing easily. In any case, it certainly sounds like an internal tranny problem. | | |
#16912 04/26/2002 5:33 AM | | Anonymous Unregistered | | Anonymous Unregistered | Sounds like a brass syncro may be going bad. On the other hand that column shifter linkage had 1000 different adjustments to catch all the gears. I would start playing with the shift linkage before I tore the tranny out. | | |
