7 members (FishinToms53, Hotrod Lincoln, Rich'sToys, Stovebolt48, 50shep, Millenimech, mason86),
75
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 19 Junior Member | | Junior Member Joined: Aug 2004 Posts: 19 | I bought a 48 PU (3100series) last yr. w/o a title. (I know that was a dumb thing to do.)
It is time to title it & I can not even read the no on the plate attached to the door frame.I removed it With a chisel & dipped it in acid ...now its worse.
Does anyone have a 1948 plate they would be willing to sell? If so please E-mail me. thanks Don
Don Meyer-PhD,mech engr
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Don,
Check with the DMV. You can probably get a new VIN for your truck....you might have to post a bond for the value of the truck....if you do it before you restore, that won't be much.
If you buy a VIN, you might run into trouble. You might have the plate...someone else might still have your title....
Here in MN, there is a process to do this and it is not too hard. You might be better off going the long way round on this one.... | | | | | Joined: Aug 2004 Posts: 19 Junior Member | | Junior Member Joined: Aug 2004 Posts: 19 |
