5 members (chemanic, Shardean, Steelonsteel, Hotrod Lincoln, 1 invisible), 129 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
#168237 04/14/2005 3:19 AM
Does anyone know if the front fenders on a 1937 11/2 ton are the same as the 1/2 ton??? Thanks
#168238 04/14/2005 4:42 AM
I'll bet the 1 1/2 ton fenders are wider.
I say that just because i've heard of people putting 1 1/2 ton fenders on 1/2 tons and 3/4 tons in the 40's models, and having to cut a chunk out of the middle and put 'em back together.
#168239 04/14/2005 4:59 AM
Not the same. Larger wheel openings for 20" tires.
To be long remembered as he's cruising in
The Passing Lane
#168240 04/14/2005 1:45 PM
Thanks guys, I thought that,but wanted to be sure,Thanks again.
#168241 04/14/2005 7:58 PM
For sure they are larger at the wheel openings.. Ive been looking too and this is definitely true.
Also Barry is a very knowledgable person in this field and topic!!! grin
Were Proud of you Barry! grin
He,s Internationally Known Too!
