1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I am swapping a Warning Light Cluster for a Gauge Cluster in a 1966 Chevy, C-10. The Gauge Cluster came with the dash cluster harness, as well as a secondary harness with two factory fuse block wires with terminals and a third wire that appears to be for the factory tach.
I have installed the Gauge Cluster but I am having trouble with the correct configuration for the tachometer. There are two terminals (one gray and one brown) on the backside of the tach with threaded terminals. They appear to be factory supplied. Does the tach have polarity? Which wire goes to the coil and which terminal is it attached to (positive or negative)?
I have consulted by '66 wiring diagram and the '63 Assembly Manual/'66 Supplement Assembly Manual and information on proper installation and wiring of a tach is not detailed in these manuals.
Any advise for a proper installation would be appreciated.
LILRED66 | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Howdy neihbor! I put one on a 60 & it had an electronic box that went with it.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | On mine gray goes to fusebox & brown to dist. Brian | | |
