6 members (UtahYork, 52Carl, Bill Hanlon, Shaffer's1950, Maybellene, Hotrod Lincoln), 155 guests, and 3 robots.
Topics128,190
Posts1,057,339
Members48,469
Socket Breaker
Socket Breaker
Just curious if 1954 hubcaps off of a 8 lug, 15 inch wheel/rim would fit/work on my 1965 , 6 lug type 15 inch wheel/rim
http://community.webshots.com/album/120809899MwOOkd
curious...
thanks,
-W
If your wheels have the correct clips they may work,,,,,
Something looks funny about the edges on those caps...
I don't think they'll fit. Y'all better measure before you buy.
Iirc, the 6 lug wheel has a smaller center than the 8 lug. The older caps fit in the center with clips, the stock caps on yours fit over the center on some lugs stamped in the wheel.
I could get you a measurement on the 8 lug wheel this evening, if you need it. I've got some stock 6 lug wheels, too, but they're out back and it's been raining since yesterday morning.
Fred
52 3600
69 C-10
Socket Breaker
Socket Breaker
I thought it was questionable...
I just liked the bow tie in the center on the dish type cap... stumblin' through the swap meet I came upon them... got me to pondering.
Thanks folks.
-W
The 3/4 ton hubcap fits in a 9-1/4" diameter ring.
Fred
52 3600
69 C-10
I put 48- 55 GMC hubcaps on my 59 GMC. What I did was buy a used on, cheap on eBay and test fit it. Worked great, looks great.
Blaine Dumkee
59 GMC 9314
Fort Smith NT
www.flickr.com/photos/northerngmc/
Socket Breaker
Socket Breaker
Hey Fred T,
thanks, I'll measure my wheel later.
-W
Woogeroo,
Don't bother, I already bought them for my '54 last week and they should be here in a day or so. wink The edges look funny on the cap because they are for a 3/4 ton and are larger and deeper than 1/2 ton caps. They are also very hard to find, I had been looking for over a year for a set. I don't think they'd fit a '65 as you definitely need clips to hold them on.
