| | | Forums66 Topics128,190 Posts1,057,342 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Just curious if 1954 hubcaps off of a 8 lug, 15 inch wheel/rim would fit/work on my 1965 , 6 lug type 15 inch wheel/rim http://community.webshots.com/album/120809899MwOOkd curious... thanks, -W | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If your wheels have the correct clips they may work,,,,, Something looks funny about the edges on those caps...
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I don't think they'll fit. Y'all better measure before you buy.
Iirc, the 6 lug wheel has a smaller center than the 8 lug. The older caps fit in the center with clips, the stock caps on yours fit over the center on some lugs stamped in the wheel.
I could get you a measurement on the 8 lug wheel this evening, if you need it. I've got some stock 6 lug wheels, too, but they're out back and it's been raining since yesterday morning.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | I thought it was questionable...
I just liked the bow tie in the center on the dish type cap... stumblin' through the swap meet I came upon them... got me to pondering.
Thanks folks.
-W | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 3/4 ton hubcap fits in a 9-1/4" diameter ring.
| | | | | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | I put 48- 55 GMC hubcaps on my 59 GMC. What I did was buy a used on, cheap on eBay and test fit it. Worked great, looks great. | | | | | Joined: Feb 2002 Posts: 2,897 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,897 | Hey Fred T, thanks, I'll measure my wheel later.
-W | | | | | Joined: Jun 2002 Posts: 81 Member | | Member Joined: Jun 2002 Posts: 81 | Woogeroo, Don't bother, I already bought them for my '54 last week and they should be here in a day or so.  The edges look funny on the cap because they are for a 3/4 ton and are larger and deeper than 1/2 ton caps. They are also very hard to find, I had been looking for over a year for a set. I don't think they'd fit a '65 as you definitely need clips to hold them on. Kevin | | |
