5 members (CuzzFuzz, greenie-reddy, TexasA&M48Truck, Peggy M, 1955 1 Series), 48 guests, and 7 robots.
Topics128,012
Posts1,055,320
Members48,419
#168020 01/27/2005 8:02 PM
Junior Member
Junior Member
Hey guys, I'm new to the site, so hello to all. I could use some help in upgrading the engine in my Apache. I have the 235 six cylinder. Is there electronic ignition upgrades for this engine? Also, I have the Rochester one barrel carb. Are there any upgrades that will work better? I don't need more power, I just want it to run smoother and be more reliable. Any help would be appreciated. Thanks
#168021 01/27/2005 11:49 PM
Riding in the Passing Lane
Petrox makes a electronic conversion kit for it. I have seen posts on this sight were you can put a HEI from a 250-292 on them. I,d like to try it. I like the model B carb myself but a lot of the bolters run them down. They sugest the carter. I think the roch. monojet is good.A little tempermental though. Welcome to the Stovebolt websight. It is great. smile
1972 Chevy c10 Cheyenne Super
#168022 01/28/2005 12:03 AM
Welcome, where's Ganado, TX?
GO RANGERS grin
Photos Updated so check them out!
#168023 01/28/2005 12:43 AM
Anonymous
Unregistered
Anonymous
Unregistered
here you go, Ganado: 90 miles southwest of Houston, 109 miles north of Corpus Christi, 139 miles southeast of Austin and San Antonio.
tony'n weatherford wink grin
#168024 01/28/2005 12:58 AM
you gotta GPS??? lol
GO RANGERS grin
#168025 01/28/2005 2:36 PM
Y
Y Offline
Hey crabb,
Did just what you're trying to do, on my '61 Apache with 235.... The Pertronix ignition kit you need is #1168, takes about fifteen minutes to install, and makes a world of difference. Keep your old points and condensor in the glove box in case you ever have trouble on the road with the pertronix. I installed the Holley/Weber 2 bbl from Langdon's stovebolt, with the water heated choke. Again, a world of difference. The Pertronix was around $85.00 as I recall, and the carb, with necessary linkage kit and manifold adapter plate was just under $100.00 from Langdon's.... www.stoveboltengineco.com
