| | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have ordered the spray glue that horvath recomended so i can insulate the 54. what can i use to cut down the noise from the engine. like a under hood pad. also will the cast aluminum valve covers help with this? i can't do anything with the floor and back wall til i move the gas tank. i plan to use the water heater jacket on the fire wall. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2004 Posts: 19 Junior Member | | Junior Member Joined: Aug 2004 Posts: 19 | I had the same problem. I ended up spraying the underside w/paintable undercoat & painted it blk. Alum valve covers do not help w/noise. The plastic ones are better at noise control. Don
Don Meyer-PhD,mech engr
