4 members (RoadsScholar, DadsFirstPickup, Maybellene, Cletus1950), 128 guests, and 5 robots.
Topics128,108
Posts1,056,233
Members48,437
#167728 03/28/2005 3:15 PM
I put an ad in a local paper for an S-10 T5 to go in my '41. I had a call this morning from a man who says he has 2 NV-3500 5 spd's from a '94 S-10. He says they are the same as the T5. I have only did research on the T5 and don't have a clue what an NV-3500 is. Will this transmission bolt up the same as a T5? Is it as good a candidate for the swap into my '41 using the 235 I have? The price is good enough $100 for both. One works good and the other he says 2nd gear is bad. I don't won't to buy the wrong thing and get stuck. Thanks for your replies.
Mike
#167729 03/28/2005 5:49 PM
The T5 and NV3500 transmissions are very different animals.
1954 GMC De Luxe COE
#167730 03/28/2005 6:20 PM
Thanks guys, I'll keep looking for a T5.
Mike
#167731 03/28/2005 6:29 PM
NV-3500 have the bellhousing integral like an automatic and will not bolt up to a 235 directly.
3500's are usually found in the 1/2 ton and larger trucks where the T-5 was in the S-10 trucks and will bolt up to the 235 bell housing with a little help.
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
#167732 03/28/2005 7:01 PM
New Venture Gear tranny specs I believe that the 3500 is aluminum bodied.
Norse
[img]http://www.norcalspeedshop.com/oldtruck/forum/smilies/sign_otn1.gif[/img]
OldTruckNetwork
#167733 03/31/2005 12:33 PM
Quote
3500's were only found in the half tons and in later S-10's to replace the T5's, they were never featured in the 3/4-1 ton trucks. They will bolt up to a small block chevy V6/V8, however their torque specs are less than desireable at barely 300 ft/lbs and while they'll take more abuse than the S10 T-5, they won't take nearly as much abuse as a proper truck tranny like the venerable SM420 or NV4500 will.
God is not on the side of the big armies, but of those who shoot best.
http://www.speedyoldtruck.com
