| | | Forums66 Topics128,281 Posts1,058,486 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 204 Member | | Member Joined: May 2004 Posts: 204 | I put an ad in a local paper for an S-10 T5 to go in my '41. I had a call this morning from a man who says he has 2 NV-3500 5 spd's from a '94 S-10. He says they are the same as the T5. I have only did research on the T5 and don't have a clue what an NV-3500 is. Will this transmission bolt up the same as a T5? Is it as good a candidate for the swap into my '41 using the 235 I have? The price is good enough $100 for both. One works good and the other he says 2nd gear is bad. I don't won't to buy the wrong thing and get stuck. Thanks for your replies.
Mike | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The T5 and NV3500 transmissions are very different animals. | | | | | Joined: May 2004 Posts: 204 Member | | Member Joined: May 2004 Posts: 204 | Thanks guys, I'll keep looking for a T5.
Mike | | | | | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | NV-3500 have the bellhousing integral like an automatic and will not bolt up to a 235 directly.
3500's are usually found in the 1/2 ton and larger trucks where the T-5 was in the S-10 trucks and will bolt up to the 235 bell housing with a little help.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
| | | | | Joined: Oct 2003 Posts: 185 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 185 | | | | | | Joined: Oct 2003 Posts: 45 Member | | Member Joined: Oct 2003 Posts: 45 | Originally posted by Hotrod6: NV-3500 have the bellhousing integral like an automatic and will not bolt up to a 235 directly.
3500's are usually found in the 1/2 ton and larger trucks where the T-5 was in the S-10 trucks and will bolt up to the 235 bell housing with a little help. 3500's were only found in the half tons and in later S-10's to replace the T5's, they were never featured in the 3/4-1 ton trucks. They will bolt up to a small block chevy V6/V8, however their torque specs are less than desireable at barely 300 ft/lbs and while they'll take more abuse than the S10 T-5, they won't take nearly as much abuse as a proper truck tranny like the venerable SM420 or NV4500 will. | | |
