3 members (52Carl, bluechev, 1 invisible), 83 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#16759 01/01/2002 2:03 AM
A guy gave me a '51 3 speed transmission today. I took the cover off and the lubricant seems to have gotten real thick and gummy. I was wondering about rinsing the insides out with a solvent(kerosene) and then refilling with transmission fluid. Any thoughts??
#16760 01/01/2002 2:40 AM
I can't see where flushing out tranny should hurt. Make sure you get it washed out as clean as you can. smile
#16761 01/01/2002 3:45 PM
we steam clean trans and r/e out all the time it will not hurt it grin
47 Chevy COE..52 TO 30
#16762 01/01/2002 8:23 PM
Suggest you drain well and wipe out bottom thoroughly to get any grit out before you flush it--otherwise you could loosen grit and put in suspension of the new grease--right into the bearings!
Personally, I'd just drain it on it's side in a warm place for a week, then add new grease. eek
