1 members (Wayne67vert),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16750 09/25/2003 3:52 AM | Joined: Sep 2003 Posts: 3 Junior Member | | Junior Member Joined: Sep 2003 Posts: 3 | I have not been able to locate brackets for the power steering pump attached to a 250 ci 6 cylinder. Since I can't seem to locate the appropriate brackets anywhere, I guess I am going to have to build them. Does anyone out there have dimensions for power steering pump brackets that would fit a 70 Chevy C10 pickup with a 250 6 cylinder installed? David '70 Chevy C10 Short Stepside
#16751 09/25/2003 4:05 AM | Joined: Sep 2003 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 37 | Did they put the integral head 250 in that far back? Had they even built it yet? (I don't think so, but it had a different bracket) if not and you have a "normal" 250; give me a few days and I'll measure the brackets I have and send you the drawings. Nothing in the local boneyard? 80's stepvans? Does your alternator bracket have the extra hole to the driver's side of the slot? | | |
#16752 09/28/2003 5:51 AM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Try early '70s Camaro, Nova, Omega in the bone yard. All of these used the 250.
'67 GMC 3/4 292 4spd
