6 members (klhansen, Tom McGrath, Shaffer's1950, David Bush, Hotrod Lincoln, JW51), 82 guests, and 0 robots.
Topics128,051
Posts1,055,735
U
Junior Member
Junior Member
U Offline
I have not been able to locate brackets for the power steering pump attached to a 250 ci 6 cylinder. Since I can't seem to locate the appropriate brackets anywhere, I guess I am going to have to build them. Does anyone out there have dimensions for power steering pump brackets that would fit a 70 Chevy C10 pickup with a 250 6 cylinder installed?
David
'70 Chevy C10 Short Stepside
Did they put the integral head 250 in that far back? Had they even built it yet? (I don't think so, but it had a different bracket) if not and you have a "normal" 250; give me a few days and I'll measure the brackets I have and send you the drawings. Nothing in the local boneyard? 80's stepvans? Does your alternator bracket have the extra hole to the driver's side of the slot?
Try early '70s Camaro, Nova, Omega in the bone yard. All of these used the 250.
'67 GMC 3/4 292 4spd
