6 members (Millenimech, mason86, delky, UtahYork, Otto Skorzeny, 1 invisible), 65 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#16743 03/25/2003 1:33 PM
Junior Member
Junior Member
I'm smack dab in the middle of installing a 5 speed s-10 transmission and I have a question. The only disc that will work is 11 inches/14 spline. My original pressure plate has a 10 inch clutch disc. Since I'm planning to use a stock '63 pressure plate, can I just get a pressure plate for an 11 inch disc (I know these trucks came with 10,11,or 12 inch clutches) and will it bolt to my stock flywheel?? Any help is appreciated.
P.S.--Does anyone know why my engine and bellhousing, out of a Pontiac, have a Chevy bolt pattern?? I was surprised.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
#16744 03/25/2003 8:42 PM
I don't know about the flywheel, but if you go to a friction shop they should be able to build you a 10" clutch disc with the right center hub pretty easily.
Paint & Body Shop moderator
#16745 04/12/2003 5:05 PM
I believe a 11' pressure plate will bolt right up. make sure to machine flywheel
Dan G
