3 members (Wayne67vert, crenwelge, 1 invisible),
475
Mod | | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16743 03/25/2003 1:33 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | I'm smack dab in the middle of installing a 5 speed s-10 transmission and I have a question. The only disc that will work is 11 inches/14 spline. My original pressure plate has a 10 inch clutch disc. Since I'm planning to use a stock '63 pressure plate, can I just get a pressure plate for an 11 inch disc (I know these trucks came with 10,11,or 12 inch clutches) and will it bolt to my stock flywheel?? Any help is appreciated.
P.S.--Does anyone know why my engine and bellhousing, out of a Pontiac, have a Chevy bolt pattern?? I was surprised.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!) 1950 Ford 2 door sedan-project
#16744 03/25/2003 8:42 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I don't know about the flywheel, but if you go to a friction shop they should be able to build you a 10" clutch disc with the right center hub pretty easily.
#16745 04/12/2003 5:05 PM | Joined: Apr 2003 Posts: 5 Member | | Member Joined: Apr 2003 Posts: 5 | I believe a 11' pressure plate will bolt right up. make sure to machine flywheel
Dan G | | |
