| | | Forums66 Topics128,188 Posts1,057,334 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2000 Posts: 52 Member | | Member Joined: May 2000 Posts: 52 | Can anyone give me some advice on how to lower the front end of our 58 with a solid front axle? I am swapping the frame out from under the 58 GMC and going back to an original setup, but want it to sit lower. Also, can you gice some advice on how the ride quality is with a lowered solid axle? | | | | | Joined: Oct 2003 Posts: 185 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 185 | | | | | | Joined: Jul 2003 Posts: 179 Member | | Member Joined: Jul 2003 Posts: 179 | Ha ha Norse...
I was thinking maybe a 4 link and bags if you don't want to go with that monoleaf route?
- Ryan
59 Apache Step 78 El Camino http://www.wsu.edu/~rsain
| | | | | Joined: Mar 2005 Posts: 24 Apprentice | | Apprentice Joined: Mar 2005 Posts: 24 | Norse,
I know your post has been up here for a good while. But I just joined the Stove Bolt, and have been looking for a drop axle for my 58 Apache all over. THANK YOU!!
I'll round off that bolt head....just as soon as I'm done strippin' this screw!
| | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | So, anybody who's done this care to comment on the pros / cons of a dropped axle vs. lowered springs? Not sure yet which way to go on mine...
Thanks, mark. 51 3100 | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | I don't know about dropped axles, but I have Patrick's monoleaf springs on the front end of my truck. They look great (dropped the front end about four inches) and they're better than standard front springs. They even eliminate the need for a sway bar. | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 |
| | | | | Joined: Mar 2005 Posts: 14 Junior Member | | Junior Member Joined: Mar 2005 Posts: 14 | Hi baldeagle,
How does the ride compare to a modern front end with the monoleaf. That is could you use the truck as an everyday driver with the set up.
Cheers Jason.
46 1 1/2ton
| | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | Absolutely use it as a daily driver. Keep in mind, I *also* added modern, gas shocks front and back.
The rear springs are the originals - just new bushings. The front has shocks mounted to 38 Dodge top mounts and fabricated lower mounts. The rear has shocks mounted to 76 Corvette mounts. The truck rides very comfortably, but I don't know that I'd compare it to a modern front end. It still has the solid axle and king pins and the original steering. | | | | | Joined: Jan 2004 Posts: 112 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 112 | Not speaking from monoleaf experience, just what I've heard from others but......... monoleafs shorten the amount of travel that you have in the front end of your truck. Hitting a good bump/pothole or RR track can cause the front end to bottom out. Maybe Baldeagle's gas shocks help him avoid this but.....If the shocks are doing the job of the springs, that is absorbing the impact, that's probably not the best solution. IMHO - a dropped axle allows you to keep the travel that the GM engineers designed the truck to have thus avoiding the above problems. The shocks (gas is good) are allowed to do just what they we're designed to do, that is, dampen the movement of the springs that have absorbed the impact of the bump. I'd talk with some people that actually have both set-ups before I made my decision. Enjoy the build.
