| | | Forums66 Topics128,082 Posts1,055,964 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16726 06/11/2004 6:50 AM | Joined: Feb 2002 Posts: 35 Junior Member | | Junior Member Joined: Feb 2002 Posts: 35 | HELLLLLLLP!
Yes, I am in carburetor hell. I very carefully laid out on a sheet of white paper all the parts I took off my carb, in the same order that the shop manual shows them in the exploded view... well....while I was blowing out the passages in the carb, I must blew a spring off the table and it is hopelessly lost somewhere in the garage! I also lost the only spring in the rebuild kit that might be able to replace the original lost spring. (this is very embarrassing...)
I lost the power valve assembly spring, which is shown in the 1965 shop manual on page 6M-12 in the exploded view as part of group 11. I am rebuilding a Rochester Model B manual choke.
Question: Is this spring included in the rebuild kit? The old spring did not match exactly the spring I lost from the kit. The original has straight sides, and the kit spring tapers down at both ends (I have the KEM brand kit).
Question: if the power valve spring is not included in the rebuild kit, where can I get a power valve spring?
Question: I found a spring that fits in the assembly, but will it work?
This is so ridiculous... any help would be appreciated....
REQUIRED READING: Truck, by John Jerome (aka "The Book of Truck") Zen Trucking
#16727 06/11/2004 10:12 AM | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | I wish I had an extra, but a method I use to find small lost parts is to stretch pantyhose over the shopvac tube or floor attachment and vacuum away..., checking them frequently. Probably want to take them off your wife first tho
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
#16728 06/11/2004 2:16 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | That spring is in the Jiffy kit that Chevy Duty sells for 12.95. | | |
#16729 06/11/2004 2:47 PM | Joined: Feb 2002 Posts: 35 Junior Member | | Junior Member Joined: Feb 2002 Posts: 35 | I appreciate your help to this carb-rebuildin' fool, who in retrospect shouldn't have been doing it in the middle of the night...
my garage floor is pretty dirty, but I might have to try the vac/nylon trick... or order another kit and ride my bike for the weekend--heck, I owe a debt to the environment anyway...
Also I might ask a local carb shop if they have a spring I can buy for a buck or twenty.
thanks for
#16730 06/11/2004 3:34 PM | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | Is that the spring under the power valve, that raises it when vacuum drops? If so, I've probably got a few spare ones. That carb was one we used for training several years ago, and I've got the training carbs stashed away somewhere in the school shop. Email me! Jerry
#16731 06/11/2004 5:11 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Hey Jerry, don't feel so all alone! I've done the same thing...those springs can end up bouncing all over the place. Small ball bearings can be real tricky too, like the ones sometimes used in carbs and automatic transmissions. | | |
#16732 06/12/2004 3:39 AM | Joined: Feb 2000 Posts: 987 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 987 | Next time go to the 5 and dime and get a cheap white towel to lay out the parts. Might not stop it from blowing away but I don't think you will make that mistake agian. At least it will keep the small parts from rolling away when you bump the work bench. Next get your self a really strong magnet. I got a magnetic pick up tool for my son when we rebuilt the roof to my garage. He just loved to go out and "Do His Job" of picking up lost/dropped nail.
Good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
