1 members (Rusty Heaps),
114
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | Hi everyone, I'm new on here as I have just bought my first Stovebolt, a '64 C10 stepside which came from San Diego, CA. These aren't too common in England so I'd be grateful for some basic advice:
My truck has a straight six and 3-speed manual. I believe the '64 engine should be a 230cu but may have been swapped - how can I easily tell a 230 from the earlier 235?
Assuming the rear axle to be stock, what gear ratio is it likely to be?
What gear ratio is top gear on a 3-speed box?
Many thanks for your help, Limey Si :confused: mon | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Welcome Limey. My folks spent time across the pond at Mildenhall base in the mid-60s, I wasn't around yet. Your 64 should have a 230, top gear is 1:1, rear ratio standard was 3.73, w/3.07 & 4.10 optional. Hard to describe the diff between 235 & 230, but a 235 is more bulky looking & usually has a draft tube. Brian | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 64 came with the 230. It should have a spin-on oil filter at the right front. 235 had an add-on filter. Stock rear gearing was 3.73 with the 3 speed. There should be a casting number on the right side of the engine. On a 230 I think it's just benind the center, raised letters in the side of the block. six or seven digits. If you go to www.inliners.org you can look in the casting lists to determine which block y'all have.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | The 235 is a lot larger six (in terms of physical size) than the 230. It's physically heavier than a 292, and about the same height. Your truck will definitely not have a 235.
A couple more things - the 230 will have two small lifter covers and the 235 will have a single large one. The 235 usually had front mounts in light trucks but the 230 always has side engine mounts.
-ftyler | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | a 235 has a distributer that the whole thing turns with the vacumn avance. | | | | | Joined: Jan 2005 Posts: 48 Junior Member | | Junior Member Joined: Jan 2005 Posts: 48 | Thanks for the information guys, looks like mine is a 230
Simon | | |
