8 members (Wally / Montana, Steelonsteel, Tronman, 1955 1 Series, Bill Hanlon, Hotrod Lincoln, LAROKE, 1 invisible),
137
Mod | | | Forums66 Topics128,201 Posts1,057,279 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 30 | ok im getting upset because i cant find a 1 ton long bed to make my wrecker out of so i want to know if it acyualy "needs" to be a 1 ton to make a tow truck with seems how i can only find 1/2 and 3/4 tons other than 1 ton panel vans its driving me nuts! | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | What kind of wrecker unit do you have. Ernest Holmes Co., had a unit called a, Holmes Jr., that would be mounted in a 1/2 ton, or 3/4 ton pickup bed. | | | | | Joined: Mar 2005 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 30 | well im thinking of a holmes 6 or a 10 tn wrecker with the custum wrecker body -one of the ones that are straight then drop of in a slope at the rear-and the unit would be a double boom system-holmes 440 or 600 possible? | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A Holmes 500, will be the largest unit you can put on a one ton, but it won't be period correct. Neither will a 440. A Holmes 400(4 ton), 460(6 ton), & 470(8 ton),with "Platform style" service body, will be period correct, for a, '60, or '61 model 1 ton truck. Check out my wreckers here, http://community.webshots.com/user/snubnose4754 , The Holmes 600(16 ton) wreckers I have, are the Platform style service body. My Holmes 525's(12 ton), & Holmes W45(20 ton), are the old style "Chariot" service bodies(pre1956). | | |
