7 members (51sub, Oldpickupman, 41 chev, Gdads51, Charles in CA, Nick in Manitou, 1 invisible),
97
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 | Hello bolters, I have a question about the dash on my 56. What goes in the three holes above the radio? On my truck the center hole is a cigarette lighter socket. The others have nothing, but look like they are for some sort of switches? Its a standard cab, 4400 work truck. No heater, no radio. Thanks!
Chris
1956 Chevrolet 4400 1959 Chevrolet Viking 60 1968 Chevrolet el Camino 2002 Chevrolet 1500HD 4x4
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | From left to right, wiper switch, lighter, hand throttle. GM used plugs that have a similar shape as the knobs to fill the holes if the truck didn't have the options, same plugs as used for the radio delete knob holes.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 162 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 162 |
Chris
| | | | | Joined: Oct 2007 Posts: 7 New Guy | | New Guy Joined: Oct 2007 Posts: 7 | i have a 57 3200 with the hand throttle, i always wonder what you we supposed to do with it. what situation did you need that? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | what situation did you need that? For using PTO powered equipment or to put it in granny in a pasture while you get in the bed and spread hay. Not for highway use. | | |
