7 members (Bill Hanlon, Otto Skorzeny, TexasA&M48Truck, John L., 55shaker, Wally / Montana, Uncles51), 96 guests, and 6 robots.
Topics128,075
Posts1,056,003
Members48,433
#166446 07/25/2007 5:40 AM
When I checked this stuff out in the store, the asphalt smell was pretty rough. Does this stuff degas quickly? How long before the smell dissipates? Or does it remain and reintroduce itself every time the exhaust heats up. I would like to put it in the doors and layer it on the floor and inside firewall.
#166447 07/26/2007 6:53 PM
I used peel & seal on my entire cab and inside the doors and haven't smelled anything in 2yrs. It gets pretty hot here in sunny California and I haven't had a problem.
I have heard that some other brands that are simillar will smell when they get hot. If you stick with peel & seal you shouldn't have a problem.
George
#166448 07/27/2007 3:33 AM
Apprentice
Apprentice
Lucforce
Where to find Peel& Seal? I haven't been able to locate the stuff in the Dallas/Ft. Worth area. Everything Ive read about it indicates its the best way to go?
#166449 07/27/2007 3:55 AM
It is in the roofing section of Home Depot. I went in there to get some and experiment with. But, when I picked it up the smell from the petrol/asphalt overcame me. For the amount of work I am doing I do not want to end up with a funk stuck to the floor that I can't get rid of, and the odor every time I sit in the thing.
#166450 07/28/2007 7:03 AM
big box stores
roofing & or windows dept ... under various names
use the stuff they use for window installation.
as to these type product(s)
see alan's page: they are ALL asphalt products
http://www.alanhorvath.com/54chevy/doors_quiet.php
his note says >>>>>> P.S. -- News from the manufacturer: This stuff will hold permanently and will not "run" or slide from excessive heat ... unless it gets over 300 degrees farenheit. :o :o They say, on hot days there will be some gasses emitting from this stuff ... perhaps not too healthy to be breathing ... but after a very hot Summer and me driving around with the windows closed and my AC on all the time, I never smelled anything at all.
Jim & Caroline
#166451 07/28/2007 6:53 PM
Yes, he says that he never smelled anything. But, he only talks about the DOOR aplication. I am worried about off-gassing from the floor.
#166452 07/30/2007 4:01 AM
Junior Member
Junior Member
I used it on my 66 and covered the whole floor. No smell though.
James T
www.fixmyprinter.com
But honey...its for us!
#166453 07/30/2007 6:34 AM
Would it be worth it to spary glue Aluminum foil over the Peel&Seal ??? the stuff i got from Summitt bascially is Peel$Seal with a layer of foil covering it ?.....but when installin i didnt notice much smell ...??
1952 Chevy Shortbed
Photos in Photobucket
#166454 08/01/2007 12:03 AM
P&S is foil backed...
#166455 08/08/2007 8:18 AM
It may leave a film on your window glass...
GMC: Get More Cash...
1958 GMC
My Webshots photos
#166456 08/09/2007 1:43 AM
I used it on my floors and in my doors... no smell and no film on my window glass....
Larry Bear
55.5 Chevy 3100 Panel
#166457 08/09/2007 1:44 PM
Well I am sold ...will pick up a roll at Lowes an give it a try on the inside of my doors ...
1952 Chevy Shortbed
#166458 08/09/2007 8:13 PM
My local Lowes didn't have it SW Radial, but they ordered it for me. The guy at the counter said he had ordered it for other vehicle restorers.
#166459 08/10/2007 1:25 PM
Thanks for the Tip Coach , Im not one to ask if they Didnt have it i woulda moved on but if they will order it for ya that is cool .
Thanks !
1952 Chevy Shortbed
#166460 08/20/2007 7:07 PM
Are you guys just using this as an insulator?
Moderated by  ndkid275, Phak1
