| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | When I checked this stuff out in the store, the asphalt smell was pretty rough. Does this stuff degas quickly? How long before the smell dissipates? Or does it remain and reintroduce itself every time the exhaust heats up. I would like to put it in the doors and layer it on the floor and inside firewall. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I used peel & seal on my entire cab and inside the doors and haven't smelled anything in 2yrs. It gets pretty hot here in sunny California and I haven't had a problem. I have heard that some other brands that are simillar will smell when they get hot. If you stick with peel & seal you shouldn't have a problem. George | | | | | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | Lucforce Where to find Peel& Seal? I haven't been able to locate the stuff in the Dallas/Ft. Worth area. Everything Ive read about it indicates its the best way to go? | | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | It is in the roofing section of Home Depot. I went in there to get some and experiment with. But, when I picked it up the smell from the petrol/asphalt overcame me. For the amount of work I am doing I do not want to end up with a funk stuck to the floor that I can't get rid of, and the odor every time I sit in the thing. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | big box stores roofing & or windows dept ... under various names use the stuff they use for window installation. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ as to these type product(s) see alan's page: they are ALL asphalt products http://www.alanhorvath.com/54chevy/doors_quiet.php his note says >>>>>> P.S. -- News from the manufacturer: This stuff will hold permanently and will not "run" or slide from excessive heat ... unless it gets over 300 degrees farenheit. :o :o They say, on hot days there will be some gasses emitting from this stuff ... perhaps not too healthy to be breathing ... but after a very hot Summer and me driving around with the windows closed and my AC on all the time, I never smelled anything at all.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | Yes, he says that he never smelled anything. But, he only talks about the DOOR aplication. I am worried about off-gassing from the floor. | | | | | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | I used it on my 66 and covered the whole floor. No smell though. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Would it be worth it to spary glue Aluminum foil over the Peel&Seal ??? the stuff i got from Summitt bascially is Peel$Seal with a layer of foil covering it ?.....but when installin i didnt notice much smell ...?? | | | | | Joined: Aug 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 26 | | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | It may leave a film on your window glass... | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I used it on my floors and in my doors... no smell and no film on my window glass.... | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Well I am sold ...will pick up a roll at Lowes an give it a try on the inside of my doors ... | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | My local Lowes didn't have it SW Radial, but they ordered it for me. The guy at the counter said he had ordered it for other vehicle restorers. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Thanks for the Tip Coach , Im not one to ask if they Didnt have it i woulda moved on but if they will order it for ya that is cool . Thanks ! | | | | | Joined: Nov 2005 Posts: 26 New Guy | | New Guy Joined: Nov 2005 Posts: 26 | Are you guys just using this as an insulator? | | |
