| | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | does anyone have any ideas on getting a sound deadener on the inside of the doors, there isn`t much of an opening to work through, also I wouldn`t want to mess up the window track, the only thing i can think of is a paint type that you could put in then roll the door to spead it out, just like lining a gas tank. TIA Mike Bourg | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the narrow rolls of peel n seal can be cut to length wrestled in and pasted on the outer skin, or you might try the cans of low expansion spray foam ... practice a bit to see how much to apply
Bill | | |
