4 members (baldeagle, Peggy M, cmayna, 49choptop), 109 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#1659 08/12/2002 5:38 PM
I've been reading the archives and found out all but one question. I think this is probably the eastiest question but one that I'm struggling with. I have a SM420 that I'm pulling out to put to rebuild, how do you get the shifter off? Can't pull the trannie with the shifer installed. Do you have to take the top of the trannie off?
Any help is better than no help.
If it ain't broke I ain't worked on it.
#1660 08/12/2002 6:37 PM
Junior Member
Junior Member
Look at the top of the trans were the stick goes in. See that little domed piece with a rectangle hole in it? Push that piece down and rotate it (right or left, can't remember). Pull that little cover off and the stick comes right out. Hope this helps.
#1661 08/12/2002 7:12 PM
I use a pair of channel-lock pliers to press down on both sides evenly.The teeth in the jaws of the pliers will grip the edges ogf the slot of the tin cover you will be removing cool
#1662 08/12/2002 7:47 PM
Thanks guys. I new it would be easy but I was stuck. I'll take it out tonight and get rolling.
Have a good one
#1663 08/12/2002 8:13 PM
With the seat cushion removed and an engine hoist that will reach, the tranny can be pulled and replaced through the passenger door.
Fred
52 3600
69 C-10
#1664 08/12/2002 8:44 PM
Thanks Fred T. I never thought of that. That will be much better than laying on the concrete floor all day.
#1665 08/13/2002 4:43 PM
I pulled my trans up through the floor by hand, my back is not quite the same anymore. I suggest you use the engine hoist or a trans jack.
Good luck.
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#1666 08/15/2002 3:10 AM
In Case you need parts here is a link for all the stuff you need for your replacement/rebuild.
http://www.novak-adapt.com/catalog/transmission_components.htm
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#1667 08/18/2002 3:24 AM
Most of ones I bring home are all dirty and rusty and don't just push down easy! frown I first oil up good, wiggle stick,let set awhile, THEN try the pliers or have used two wood sticks to hold on each side of lever and push down, and hope to have enough grip to turn the cap. Once off, you can clean it up and lube, and sometimes even push back on by hand! After you take it out, if side pins are good shape in hole, take a 3/8" eye-bolt and put a couple of washers on it with a nut at top and bottom. Cut a groove in one side of washers to allow them to pass past the one side pin in hole. Washers should be about size of big top hole, but pass thru. Lower this device down into hole by putting one side below one side pin, and pass slot past other pin, turn it to have solid washer under the two pins, and pull up with your chain or hoist hook. We used to use this device or like it on factory 4-spds at work. You can swing them all over and good balance too. Just make sure you don't swivel the cut-out notch back under pin or it will let go! I made one and use it alot when I'm removing trans. I lift up on trans from inside with picker, but lower it down to floor and set on a roller dolley make of wood and roll out from under truck.
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
