1 members (carbking),
103
8
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 50 Member | | Member Joined: Jun 2002 Posts: 50 | I've been reading the archives and found out all but one question. I think this is probably the eastiest question but one that I'm struggling with. I have a SM420 that I'm pulling out to put to rebuild, how do you get the shifter off? Can't pull the trannie with the shifer installed. Do you have to take the top of the trannie off? Any help is better than no help. Thanks
If it ain't broke I ain't worked on it.
| | | | | Joined: Jul 2001 Posts: 19 Junior Member | | Junior Member Joined: Jul 2001 Posts: 19 | Look at the top of the trans were the stick goes in. See that little domed piece with a rectangle hole in it? Push that piece down and rotate it (right or left, can't remember). Pull that little cover off and the stick comes right out. Hope this helps. | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I use a pair of channel-lock pliers to press down on both sides evenly.The teeth in the jaws of the pliers will grip the edges ogf the slot of the tin cover you will be removing
| | | | | Joined: Jun 2002 Posts: 50 Member | | Member Joined: Jun 2002 Posts: 50 | Thanks guys. I new it would be easy but I was stuck. I'll take it out tonight and get rolling. Have a good one
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | With the seat cushion removed and an engine hoist that will reach, the tranny can be pulled and replaced through the passenger door.
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2002 Posts: 50 Member | | Member Joined: Jun 2002 Posts: 50 | Thanks Fred T. I never thought of that. That will be much better than laying on the concrete floor all day.
| | | | | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I pulled my trans up through the floor by hand, my back is not quite the same anymore. I suggest you use the engine hoist or a trans jack.
Good luck.
Tom
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
| | | | | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Most of ones I bring home are all dirty and rusty and don't just push down easy!  I first oil up good, wiggle stick,let set awhile, THEN try the pliers or have used two wood sticks to hold on each side of lever and push down, and hope to have enough grip to turn the cap. Once off, you can clean it up and lube, and sometimes even push back on by hand! After you take it out, if side pins are good shape in hole, take a 3/8" eye-bolt and put a couple of washers on it with a nut at top and bottom. Cut a groove in one side of washers to allow them to pass past the one side pin in hole. Washers should be about size of big top hole, but pass thru. Lower this device down into hole by putting one side below one side pin, and pass slot past other pin, turn it to have solid washer under the two pins, and pull up with your chain or hoist hook. We used to use this device or like it on factory 4-spds at work. You can swing them all over and good balance too. Just make sure you don't swivel the cut-out notch back under pin or it will let go! I made one and use it alot when I'm removing trans. I lift up on trans from inside with picker, but lower it down to floor and set on a roller dolley make of wood and roll out from under truck.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
