3 members (mick53, Uncles51, 1 invisible),
93
Mod | | | Forums66 Topics128,127 Posts1,056,674 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Anyone know the original location for the heater & defroster switches on a 41 -46 PU dash? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my 46 had a small switch assembly mounted to the bottom of the dash on the outside of the column .... it was a deluxe heater with 2 switches for the 2 seperate fans, one floor heat, one defrost, but I think they all were similarly mounted
Bill | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | You should see holes in the bottom of the sdash that these naturally fit in. The toggle (like a light switch) switches are correct.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
