0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
#166080 05/12/2007 12:10 AM
Hey guys, So I'm replacing my heater core on my 1960 C10 with the deluxe heater. I have the new core I bought from Napa that they say is for this year. Well first off It doesn't have a mounting place for the heat valve. just the 3/4 and 5/8 tubes coming out. I had to by a inline valve. 2nd the inlet and outlet tubes are in different places. They go above the core.( I know the oulet is on the top but my original inlet tube is on the side.) I tried to go to different stores to find a different core. No luck they are all the same style. So my question is Has anyone had this problem? Do I have to modify the top plate that hold the core? can I heat and try to bend the tubes? Is there a place that will sell a core with the inlet tube and valve that's on the side? HELP! I also posted this in Engine and Driveline since I don't know wether this would be consider engine or interior. thanks!
Thanks,as always -Danny
1960 C-10 Stepside,Longbox
235,4spd 3.90 diff.
APACHEMANSLIM60
Look your truck up here there is two options for your heater core recirculation heater or fresh air, one is on top the other on the side.
http://www.rockauto.com/
Darrell
Moderated by  ndkid275, Phak1
