| | | Forums66 Topics128,047 Posts1,055,534 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16597 11/20/2003 11:37 PM | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | After running my '59 for a couple of months, yesterday I started it and it was sputtering and trying to die, I saw that the carb was POURING out fuel out of the throttle shaft!!! You guys think that a re-build will fix the problem or is a new carb the answer? (The 235 w/ 1B Rochester was very rich before and I couldn't get the soot of the plugs) The truck had sat in my Dad's barn for 3 years before I had it shipped out here. Thanks for your help in advance.
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#16598 11/21/2003 1:01 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yep, you need to rebuild it. Most likely the float is stuck and it is flooding out.
#16599 11/21/2003 2:10 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I agree that a rebuild is in order, but you probably need to bush the throttle body shaft while you're at it. They have a bad habit of throttle body wear, and allow air to suck in where they shouldn't.
Fred 52 3600 69 C-10
#16600 11/21/2003 3:47 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | I had the same problem on my '61 Apache. A "rebuild" will not generally include re bushing the throttle shaft, as it didnt on mine. I was able to locate a complete used "throttle body" (the cast iron bottom part, that the shaft is in) from one of the vendors for around $20.00 plus shipping. I'm figuring you cant get one rebushed for that, but then again, I couldnt find anyone that was willing to do it at all in my neck of the woods. Not sure about rules concerning posting vendor info here, so contact me via e mail if you need the info. [email protected] | | |
