2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Guys,
The door glass fuzzies and weatherstripping on my '54 4-door is totally shot. Do most of you replace this stuff yourself, or farm it out? How hard a job is this to do correctly? Any special tools needed?
Thanks, chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | not hard to do at all, when you order a set make sure they are the re-pops brand. if that supplier doesn't carry them try another supplier. The re-pops brand is the best i've found. Comes with staples and a little drill bit and are pre formed. If staples aren't your thing than 1/8 rivets will work. Hopes this helps.
Wilbur | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | You can do it yourself. This Will Help Some
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
