6 members (FAST55, 2-Ton, Oldcaliforniakid, Ponchogl, Hotrod Lincoln, Donf), 99 guests, and 2 robots.
Topics128,042
Posts1,055,519
Members48,424
#165715 03/18/2007 12:16 PM
I would like to use a '52-'54 door latch and striker on my 1949 3600. Will the latch mechanism fit into the door with the same screw points as the '49. Can I put it in "un-modified"?
My 1949 3600
http://picasaweb.google.com/spencer500/1949Chevy
#165716 04/17/2007 2:32 AM
Nope. And the other issue you have is that the door handles are different and you don't have the backing plate on the inside of the door to run the screw into the handle. I have a '51 and a '53. Door handles were changed in 52. I wanted to put the '53 style handles on my '51 and decided it was too hard.
#165717 05/09/2007 1:21 PM
Hi Spencer
I wont to put in my chevy 3600 47-51 door latch and striker in my 1952 chevy,opposite than you, the latchs holes are not the same, the 49 ext handle not fit into the 1952 door, the 1949 drive door has the hole for the lock, the 1952 not because this lock is the same push botton.
In summary, don't work without any modification
Moderated by  ndkid275, Phak1
