7 members (Southerntruck, 1955 1 Series, cmayna, Cletus1950, Wayne67vert, Otto Skorzeny, Hanks custodian),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#16542 11/03/2002 1:27 PM | Joined: Mar 2001 Posts: 4 Junior Member | | Junior Member Joined: Mar 2001 Posts: 4 | | | |
#16543 11/04/2002 5:59 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Good looking engine, until I saw that orange oil filter. Engine Oil Filters Overview
Fred 52 3600 69 C-10
#16544 11/04/2002 2:54 PM | Joined: Oct 2002 Posts: 29 Junior Member | | Junior Member Joined: Oct 2002 Posts: 29 | Great looking engine! I was thinking of also of installing the offy intake. What size carb are you using? Keep the pictures coming.
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!) 1950 Ford 2 door sedan-project
#16545 11/04/2002 5:05 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Advise well taken on the filter, Fred T.
I'll be using a new Edelbrock 500 cfm, 4 barrel carburetor. I've been told that it's a bit too large for a stock cam, so it will probably be jetted down some for optimum use. The engine is .060 over, which yields 301 ci so I don't expect any major problems with the Edelbrock.
The headers required some work - some bending with the hammer on the #1 & #2 exhaust, and quite a bit of grinding down the flanges in order for the intake manifold to fit and bolt up just right.
The only thing I'm missing for optimum performance is a mild cam, which I revisiting for the second time. :confused: | | |
#16546 11/04/2002 6:25 PM | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Thanks for posting that link, Fred T. There's some interesting info to be found there... Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
#16547 11/04/2002 7:29 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I found that on the 67-72 board recently. Really opened my eyes because Fram used to be one of the best filters on the market. Passed it around here at work and all the engineers were as astounded as I was.  I had wondered why they could sell their filters for so cheap, and it seemed that when someone came out with a lower priced filter, Wal-Mart met the price across the board. Holy Cow, Batman, we better get the Batmobile in for an oil change, quick!
#16548 11/04/2002 8:47 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, I have two vehicles that are sensative to oil filter quality, my BMW and my Miata. The BMW has an oil cooler that requires the antidrainback valve on the filter to work right. Otherwise it drains and it takes too long for the oil pressure to come up. I use either Wix or Purolator filters on that car. The miata has 16 valves with hydraulic lash adjusters and they get noisy if the filter doesn't filter enough or the antidrainback valve doesn't function. Again, Wix, Purolator, Mobil1, or OEM only for that car. The fram filter I tried also dropped the oil pressure too much (the car has a very accurate gauge).
On the other hand, in a 216, 235, or 261 any oil filter is better than none so fram is probably ok.
#16549 11/07/2002 10:45 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | What do you think about the fake stainless/aluminum water pump and upper thermostat housing? Quite a paint job, eh.  | | |
