| | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | Has anyone added a/c to their 60-66 truck or suburban? If so what or who's kit worked best?
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've never used the kits. First of all, they rarely include the engine brackets and that's usually the biggest problem if you're plumbing into an odd-ball engine. If your engine has a compressor mount already, they might do the job!
I like to gather my parts from local suppliers (check the yellow pages) Most carry all the components and are more than willing to work with a hobbist. Even to the point where I bought all the components to fit, hoses too, and then they crimped all the connections when I got everything fitted to meet my needs. Being able to run the lines and mount the components where I wanted them was a serious consideration. Evacuation and charging cost me $35.00 from a local A/C shop. My systems averaged less than $700.
It takes time to gather and figure out how to make everything work properly, but isn't that what building these ole trucks is all about? You said it "sometimes the slow way is the right way". Hope this helps. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | I bought my parts from swapmeets.They are parts from that erea. Not dealer add on's, but the kind that Sears would have put on. No one could afford dealer add on's at that time , but everybody had credit with Sears. | | |
