0 members (),
135
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 125 | On a 51 truck, was the floormat standard? I have never seen a picture of a truck with carpet before. I am considering buying carpet, but I was wondering if that was an option originally. What items do you need to install the floormat? Is there something that goes underneath the floormat and how is the floormat attached? I am pretty sure I will go with the floormat if it was how the trucks originally came. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | THe rubber floormat was orignal.
Justin,
The rubber floormat is held in place with a few metal "pins" that are welded to the firewall/floorboard at the upper edge of the floormat. Carper was neither standard, nor an option, not an accessory (from GM).
I do not think that any insulation was originally used but felt insulation floorpads do provide good sound deadening. Some vendors sell floorpads that you have to cut to fit and other vendors (Brothers &/or LMC ?) sell floorpads that have been cut to fit, with cut-out slots and holes (no higher cost for this convenience).
Tim | | |
