| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 22 | I did a search and could not find the answer to my questions. I heard that you should spray your cardboard headliner with a solution of water and ammonia? What would the mixture be percentage wise? Also do you have to worry abt getting it too wet? Do you spray both sides to get it wet enough? Thanks for any help you can give. Mark 1937 1/2 ton | | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | i rolled my cold...well as cold as we can get in arizona, but the water/ammonia solution is supposed to work pretty well. don't know the ratio of water vs. ammonia, although i would imagine just the water would work fine considering the evaporative rate in our part of the world.
i can't remember where i read the thread regarding headliner installation but what i remember is that you don't want to get it too wet. the cardboard will break down if saturated too much.
best advice i can give you is just take your time. a second set of hands is always a good idea, but i did the headliner on my 50 by myself. just takes a little more articulation and a little more profanity! | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | i think it was about 10% but as stated above you don't want to get it too wet. I plan to lay mine out flat and hold down with heavy object untill it gets the "roll" out and think sprinkle lightly as needed.
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | 80% ammonia and 20% water. Use a spray bottle like a Windex bottle and spray the back side of the headliner lightly...just enough to dampen, not soak | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have always been told to use 50/50 but I guess climate would need to be considered, you may want to get more in the corners (or more of the bent area) and little in the smaller bends. and only the backside. as Texaholic2000 says you only need to dampen and don't get it drippen. | | |
