| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Started putting in new felt and rubber seals in the side windows today. Started but not finished. Among other items that slowed me down, the ventilator (wind wing) glass came loose in the frame while removing the wind wing. I slid it back into place after I got everything out, but while it feels pretty solid, I definitely want to reinstall it in the channel properly. What is the material that you apply to the glass before placing it in a clean channel? Any ideas on where to get it. I'm going to check a local glass store/installer tomorrow, but suggestions on installing the glass back in the frame and what materials I will need will be appreciated. On a side note, once I get the driver's side door done I should know what not to do when I tackle the passengers side door.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year?
Most of the Advance-Design parts vendors sell glass setting tape. Your year might not use this.
There are different thicknesses of glass setting tape. I had to use three different thicknesses for the various pieces of glass on my Suburban. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yer local auto glass shop will fix ya up with the glass setting tape Tim mentions, make sure ya take the glass and frame along so they can see what's needed
Bill | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I agree with Bill. When I did the side glass in my 55 2nd I got the tape from a local automotive glass company. They were happy to help. The older auto glass companies have the tape sitting around and don't use it too much anymore, so they are happy to help. And it comes in various thickness' so take the glass and frame with you.
Life is good.
Dennis -there is nothing stronger than the heart of a volunteer-
