Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (jmoore, DoubleB, Sjm, Ponchogl, Dakota Bob, Wally / Montana), 88 guests, and 4 robots.
Topics128,275
Posts1,058,439
Members48,490
#165031 12/02/2006 11:53 PM
Has anyone installed three point seatbelts in their truck? the bottom holes are easy -- done those before but how do you attatch the top part to the sheet metal. I expect you would need a special fixture to put inside a drilled hole. It would have to be pretty strong to hold up in an accident.
Appreciate any advice
#165032 12/03/2006 2:05 AM
V
V Offline
Not yet but check out Deve's site with how to instructions:
http://www.speedprint.com/Deves50/seatbeltassembly.php
#165033 12/03/2006 2:38 AM
I found this little tidbit of information in one of my accessory manuals.
Factory lap belt for \'60-\'66 Chevy truck illustration
I was not aware that factory three point belts were available as a dealer option on the 4-5-6 Chevy trucks. I learn something new everyday about these trucks.
#165034 12/03/2006 3:14 AM
I welded a lug nut to a large body mount washer, drilled a few holes in the same place as a buddy's '69 C10, taped the washer/nut combo to an old antenna. I stuck it up into the pillar & plug welded it thru the holes I drilled. I used a 7/16 lug nut as it was the same thread as the bolts. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#165035 12/03/2006 6:33 AM
I installed 3 point retractable belts in my 54 panel. Instead of getting inside the panels I surface mounted 3/16 steel plates in the proper places. Each plate was about 3X5 inches with nice rounded corners. The seat belt mounting bolt size was 9/16 so I drilled into the plates and welded a 9/16 nut on the back side of the plates. Then I cut a hole larger than the nut into the truck and surface mounted by welding a continuous beed around them. I cleaned up the welds and used a little glazing putty to dress them up. Not original but either are the belts. It's a very strong connection provided it is welded correctly. It also looks good and will hardly be noticed with the belts hanging in front of them. Good luck.
All the best, Ted
#165036 12/04/2006 4:02 AM
This forum is the greatest--I'd be lost without it
Thanks for the great tips guys. I cant weld but if I can get the washer and nut inside the drilled hole that should do it, right?
Moderated by  ndkid275, Phak1
