7 members (55shaker, Shade Baby, Bill Hanlon, Jon G, 78buckshot, TrknGMC, 1 invisible),
109
Mod | | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Has anyone installed three point seatbelts in their truck? the bottom holes are easy -- done those before but how do you attatch the top part to the sheet metal. I expect you would need a special fixture to put inside a drilled hole. It would have to be pretty strong to hold up in an accident. Appreciate any advice | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I found this little tidbit of information in one of my accessory manuals. Factory lap belt for \'60-\'66 Chevy truck illustration I was not aware that factory three point belts were available as a dealer option on the 4-5-6 Chevy trucks. I learn something new everyday about these trucks. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I welded a lug nut to a large body mount washer, drilled a few holes in the same place as a buddy's '69 C10, taped the washer/nut combo to an old antenna. I stuck it up into the pillar & plug welded it thru the holes I drilled. I used a 7/16 lug nut as it was the same thread as the bolts. Brian | | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | I installed 3 point retractable belts in my 54 panel. Instead of getting inside the panels I surface mounted 3/16 steel plates in the proper places. Each plate was about 3X5 inches with nice rounded corners. The seat belt mounting bolt size was 9/16 so I drilled into the plates and welded a 9/16 nut on the back side of the plates. Then I cut a hole larger than the nut into the truck and surface mounted by welding a continuous beed around them. I cleaned up the welds and used a little glazing putty to dress them up. Not original but either are the belts. It's a very strong connection provided it is welded correctly. It also looks good and will hardly be noticed with the belts hanging in front of them. Good luck.
All the best, Ted
| | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | This forum is the greatest--I'd be lost without it Thanks for the great tips guys. I cant weld but if I can get the washer and nut inside the drilled hole that should do it, right? | | |
