0 members (),
94
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | Can a 59 Apache steering wheel be mounted to function properly on a 79 Blazer steering column? Has anyone done this or tried? Thanks
Ken in NY
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't see why not. GM used the same spline size on the steering column up to at least the mid 90's. If it's a tilt column, you'll want to tear down into the tilt mechanism and tighten the 4 bolts that hold it together, put some red locktight on them. These bolts comming loose is the primary cause of the "floppy column" problem that you see on GMs.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 45 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 45 | Thanks Bill. That is the news I was hoping for. Ken
Ken in NY
