0 members (), 84 guests, and 2 robots.
Topics128,062
Posts1,055,857
Members48,428
#164771 09/01/2005 10:37 PM
I've a seen a picture on here before about building a nice shelf above the in cab gas tank to make it look better, and to have a place to put things..Does anyone remember who did that? I'm sure more than one bolter has done this..Thanks, Steve
#164772 09/15/2005 4:40 AM
Mounted my speakers on the gas tank lip and just use the top of the tank to put things. The seats do a good job of containing the stuff.
If you really think you need a shelf you might try using the tank lip as a stabilizer--wood or ? on either side and then build your shelf from there. The problem is if you have much slant on your seats you won't have room to store much.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
Moderated by  ndkid275, Phak1
