| | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | does anyone know how to remove the key switch from an '82 chev. steering column? I DONT have the keys. gotta get the old out to either replace it or get new keys made. thanks in advance for your knowledge/guesses. | | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 |
64 c10 89 rs 62 econoline 50 ford coupe
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | sorry, its a '82 pass. car. im told theyre all the same. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | boy, I have heard that before  Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | thieves usually use a slide hammer,thread it into the key hole & whack away,I have seen it done & was amazed how well it worked,,or they just take a reg hammer & break off the whole end of the column  (not recommended if you wanna re-use the column). I usually just chip the old cyl away w/a small chisel. brian | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Thank-you Joe. Thats just what i needed. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | While you're in there, you might as well take the bolts out for the tilt mechanism and put some Loctite on them. They have a tendacy to back out. That's what causes the "floppy column" problem. I used the red kind on my Blazer, hasn't come loose anymoere.
Bill Burmeister | | |
