1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
does anyone know how to remove the key switch from an '82 chev. steering column? I DONT have the keys. gotta get the old out to either replace it or get new keys made.
thanks in advance for your knowledge/guesses.
chev what?
64 c10
89 rs
62 econoline
50 ford coupe
sorry, its a '82 pass. car. im told theyre all the same.
boy, I have heard that before grin
Redryder pix
My Hotrod
thieves usually use a slide hammer,thread it into the key hole & whack away,I have seen it done & was amazed how well it worked,,or they just take a reg hammer & break off the whole end of the column grin (not recommended if you wanna re-use the column). I usually just chip the old cyl away w/a small chisel. brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thank-you Joe. Thats just what i needed.
While you're in there, you might as well take the bolts out for the tilt mechanism and put some Loctite on them. They have a tendacy to back out. That's what causes the "floppy column" problem. I used the red kind on my Blazer, hasn't come loose anymoere.
Bill Burmeister
Moderated by  ndkid275, Phak1
