4 members (Joe H, 68ironhead, baldeagle, 78buckshot), 72 guests, and 5 robots.
Topics128,014
Posts1,055,329
Members48,419
#164658 08/21/2006 4:28 PM
Hey guys,
On my 46 I have the horn button, spring and bolt off, before I put the puller on it do I need to remove anything else? I looks like a large washer of some sort is still in there but it wont come out.
Thanks in advance
Ed
#164659 08/21/2006 8:35 PM
If you need to buy a puller don’t buy a steering wheel puller.
Buy a harmonic balancer puller and you can pull more than just your stock steering wheel. You can pull grant steering wheels also. (you will have to buy some proper sized bolt)
The washer is probably stuck, should be okay as long as the puller will slide through the washer.
#164660 08/21/2006 9:18 PM
That is what I thought but wanted to ask first. I already bought the steering wheel puller but one can never have to many tools. smile
Thanks again
Ed
Moderated by  ndkid275, Phak1
