| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Hey guys, On my 46 I have the horn button, spring and bolt off, before I put the puller on it do I need to remove anything else? I looks like a large washer of some sort is still in there but it wont come out. Thanks in advance
Ed | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | If you need to buy a puller don’t buy a steering wheel puller. Buy a harmonic balancer puller and you can pull more than just your stock steering wheel. You can pull grant steering wheels also. (you will have to buy some proper sized bolt)
The washer is probably stuck, should be okay as long as the puller will slide through the washer. | | | | | Joined: Jul 2005 Posts: 308 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 308 | Thanks, That is what I thought but wanted to ask first. I already bought the steering wheel puller but one can never have to many tools. Thanks again Ed | | |
