0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 17 Junior Member | | Junior Member Joined: May 2006 Posts: 17 | Did you have to take the metal pan off that the old seat sat on because I would like to do the same thing your doing to my 52.
RYAN
Smoke Em if You Got Em
RYAN
| | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Mine is a ’58.
I’m going to have to make some spacers to get them level, but shouldn’t have to remove anything from or modify the truck. | | | | | Joined: May 2006 Posts: 17 Junior Member | | Junior Member Joined: May 2006 Posts: 17 |
RYAN
| | | | | Joined: Aug 2006 Posts: 13 New Guy | | New Guy Joined: Aug 2006 Posts: 13 | Fantastic tip on interior mod. I'll keep this in mind as a second option for my 59. BTW, what are the measurements on those seats...or did you just fit and pray?
Thanks Vette
59 Fleetside Longbed-350 Crate 76 Jeep J20 Ambulance 2007 Wrangler X
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Flamin 52, The 59 does not have the pan like the 52. Any seat up grade in the 52 involves taking off the pan. Its also a little tight without taking out the gas tank. This is a major undertaking.
52pu
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Jul 2006 Posts: 23 Junior Member | | Junior Member Joined: Jul 2006 Posts: 23 | Any seat that you want to fit to the early trucks with the seat risor and underseat tank will require you to section the seat frame. Easy task. Just cut out the verticals from the adjusters up to the bottom of the actual seat.(cushion). | | |
