3 members (Danielbolt, bluechev, 1 invisible), 104 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
I just wanted to share this . I purchased new grey door panels for my 51 1300. They didn't come with the holes for the arm rests or marked in any way.I took 2 1/4 -20 nc bolts and sawed off the caps then proceded to grind the cap side to a cone shape leaving about a 1/16 flat round spot on the end.Boy they get hot fast! Then I screwed them into the door leaving them out about 1/4 inch. Then I fitted the new panel on and using my hand I applied pressure to make an indent.Remove the panel again and there will be 2 nice indents on the inside ready to drill.The fit was very precise.The drilled hole was a bit raggy but the arm rest covered it.Next time I would try a 3/8 leather punch for a cleaner hole.
coolchevy,
Good advice. I have used the same technique on cardboard headliners for the holes for the interior sunshades.
Tim
Way to go!
cool
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
Guys, another way of transferring those holes is to use the proper sized allen setscrews. Screw them into the hole by hand upside-down, then you can use the same method that coolchevy did.
Moderated by  ndkid275, Phak1
